B-17 Parts available
A marketplace of B-17 parts...where to find them, where to sell them, where to trade them, where to build them.
mcelhaney14
Post by mcelhaney14 »
Hi everyone, I'm new to the form here. I have some B-17 parts that I would like to sell and wanted to see if anybody is interested. This is just a quick list from my memory so there is probably more. Most if not all of the parts are from a G model.
1 control wheel (new)
4 bomb bay door jackscrew assemblies
1 bomb bay door drive motor with gear box to go to forward jackscrews
several flap actuating jackscrew gearbox assemblies
1 engine mount
1 set of lord mounts, enough for one engine. (new)
4 cowl flap actuators and partial sets of cowl flap door linkages
4 fuel boost pumps (new)
1 tail gear retracting assembly, needs new jack screw
1 main gear retract assembly
1 main gear retract motor
1 main gear 90 degree gearbox, for manual extension I believe
misc instruments
9 (I think) Breathing oxygen bottles, the large non portable ones
2 turbochargers (rough shape)
2 (I think) lower main gear legs, been demiled
2 Intercoolers for the turbocharger, been demiled
1 turbocharger oil tank (rough shape)
Most of the parts are from a scrapped aircraft and have been exposed to the elements, but are in rebuildable condition.
If interested e-mail me at mcelhaney14@yahoo.com
Parts are located in southern california and I would like to sell it as a lot.
Thanks
William
mcelhaney14
Updated list
I went through my stuff and have a more accurate list and pictures of most parts. Here goes.
2 turbochargers
2 intercoolers (looks like inboard ones)
1 main gear retract screw
1 engine mount
1 tail gear retract assy. (screw cut)
2 lower main gear legs (demiled)
1 control wheel (new with broken switch)
1 deice valve?
3 fuel selector valves?
1 piece on supercharger duct work with electric motor
6 cowl flap actuators (2 have been demiled)
2 sets of dynafocal mounts (1 new set, 1 used, seem to be different between the sets)
1 set of red green amber recognition lights (new)
1 small unknown 90 degree gear box (maybe not B-17?)
1 pulley quadrant (possibly lower throttle quadrant stand)
1 oil tank
2 misc carrier bearing assy. (maybe cockpit brake system)
1 complete accumulator
1 set of accumulator end caps and rings plus piston
1 box of curtis wright orings (maybe intake tubes)
41 oxygen signal sensors (new)
1 windshield wiper motor (new)
2 windshield wiper converters (new, I believe)
3 compass radio control boxes (a bit rough)
2 misc electric motor mounts (new)
4 fuel strainer assy
6 flap drive gear boxes (3 complete, 3 partial, I should have a few more parts to complete these, just have to find them)
misc triangular bracket and a part labeled inspection door
3 90 degree landing gear manual extension gearboxes
1 main landing gear retract motor (new I believe but has some corrosion)
cowl flap linkage to do one engine
4 manual extension handles
1 hydraulic reservoir
1 possible trim drum component
4 bomb bay door drives, 2 have bent screws and I should be able to find the last couple of parts for the disassembled one
1 bomb bay door drive motor and upper gearbox
misc 2 pulley casting
misc instruments
1 unknown hook bracket
9 breathing oxygen bottles
2 Sensitive equipment destruct devices
Once again, I would like to sell everything as one lot. I know I talked to a couple of people before this post and told them $3500 for everything, but I didn't realize that I was forgetting so much. I feel that everything should be easily worth $5000, so that is the new price for everything and including whatever else I may find when I go back through my stuff looking for the last odds and ends.
Thank You
William
mcelhaney14
Re: B-17 Parts available
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
mcelhaney14
