Martin 250CE in a B-17?
Hello,
This photo was posted in a FB Allied Pilots group and is reported to be two WASP flight crew at Buckingham Field. Buckingham was a gunnery training base so this may have been a gunnery training flight. What I find unusual is that there is a Martin 250CE where the normal Sperry A-1 would be. Have any of you seen Martin turrets in the forward position on a B-17? The Martin was standard in the radio room area of the YB-40 but not up front.
What do you think?
What do you think?
Re: Martin 250CE in a B-17?
Taigh,
Thanks for posting this. I, for one, have never seen a Martin turret installed at the top turret position. Presumably, for gunnery training. Is the mounting ring gear the same or would it have taken a more involved modification?
Too bad no serial is presented.
That looks like Dreamboat
Dreamboat was 41-9112
Dreamboat was also called Reed Project
Looks like you got it…or at least a B-17 with a Martin turret.
Maybe TDY to Buckingham?
Nick Veronico
B-17G tail turret project
http://www.wreckchasing.com
www.amazon.com/author/nicholasveronico
With the help of Jack Fellows I think I've been able to take this a bit further. The WASP pilot is Dawn Seymour and this appears likely to be the B-17 she was photographed in.
For more of the story:
https://ezramagazine.cornell.edu/Update ... ymour.html
That's certainly not the "Dreamboat"/Project Reed/Reed Project aircraft.
Nick Veronico
Is that a Buckingham plane? I've been looking for Buckingham B-17s as the Paducah plane started its career there. Other aircraft types based there had "FM###" fuselage codes, but the only two Forts from that field I've found have two-digit numbers like Sebring or Lockbourne (from a YouTube video about the base; the serials 42-30492 and 42-30496 check out with Osborne as having served at Buckingham):
http://fuselagecodes.com/id69.html
Steve Birdsall wrote: ↑Mon Apr 17, 2023 11:48 pm With the help of Jack Fellows I think I've been able to take this a bit further. The WASP pilot is Dawn Seymour and this appears likely to be the B-17 she was photographed in.
Disagree
The second photo is a standard B-17 upper, where the photo that started this thread is a Martin (look at the difference in the turret ring)
Disagree that it is the same ship - no paint chips on the window frames (behind pilots sliding window) or on the upper glare shield windows.
As mentioned, may or may not be dreamboat but that is the only B-17 that I know of (off the top of my head) that has had this mod; but the photos posted by Steve is not the same ship
Chris Brame wrote: ↑Tue Apr 18, 2023 2:03 pm Is that a Buckingham plane? I've been looking for Buckingham B-17s as the Paducah plane started its career there. Other aircraft types based there had "FM###" fuselage codes, but the only two Forts from that field I've found have two-digit numbers like Sebring or Lockbourne (from a YouTube video about the base; the serials 42-30492 and 42-30496 check out with Osborne as having served at Buckingham):
Chris
I do not have a single ship with Buckingham codes - only found these two digit codes at Lockbourne
Points taken. I’ve since learned that Flip Marchese and Ross Smith have been investigating these same photos, and concluded that #60 is this one, B-17F-130-BO 42-30949, in earlier days named Jumpin’ Jive.
Steve Birdsall wrote: ↑Thu Apr 20, 2023 12:34 am Points taken. I’ve since learned that Flip Marchese and Ross Smith have been investigating these same photos, and concluded that #60 is this one, B-17F-130-BO 42-30949, in earlier days named Jumpin’ Jive.
I am not seeing a connection with Buckingham according to Osborne
42-30949 Del Cheyenne 24/8/43; Tinker 9/12/43; 3501 BU Boca Raton 14/7/44; 4208 BU Mines
17/7/44; 504BG Fairmont 29/8/44; 3501 BU Boca Raton 4/9/44; 2532 BU Randolph 11/4/45; RFC Walnut
Ridge 20/12/45.
but, there is a 4-month gap between Cheyenne and Tinker
It could be the blacked out nose art does fit Jumpin Jive
