B-17 Shark Tail drawings
A dedicated forum to getting a B-17C back in the air.
Finished the latest drawing recreation.
From this:
To this:
jmkendall
Re: B-17 Shark Tail drawings
Post by jmkendall »
Great Work! That sort of work is tedious but necessary!
Joe
Amazing. What a difference and a different perspective than normally seen on the airplane. Cool.
partschaser
Post by partschaser »
This really is impressive. But what I find more interesting is that the original was done by hand by some draftsman. Imagine doing all the drawings for a B-17 by hand! Rows and Rows of draftsmen at their tables laboring over one part at a time.
Looking at the drawing, I see a line that seems to indicate the break between the inboard and outboard wing panels. Is this really the seperation line or an artifact of the draftsman? Is there a large difference between the C/D model wings and the E and later wings?
Nice work Bill,
Bill K
partschaser wrote:Looking at the drawing, I see a line that seems to indicate the break between the inboard and outboard wing panels. Is this really the seperation line or an artifact of the draftsman? Is there a large difference between the C/D model wings and the E and later wings?
The C/D wing has structural differences (mostly material thickness),
but the planform is the same. The line between the inner and outer
panel is a little off in the drawing, but I kept it there to be true to the
original.
Just another quick glimpse at the slow moving B-17C project.
Per a request.
Close up of the B-17C fuselage drawing.
Lucky 13
Post by Lucky 13 »
Bill E-mail me this drawing
Keep the show on the road.
384thBG
Post by 384thBG »
Hi Bill, what was the process used to create the cleaned up clean drawing? Did you do it yourself or did others help you? Who is printing the super large sheet of the fuselage elevation for you? - thats expensive!
Sorry if you've written about this before, just post the link if its easier. I'm familiar with some of this clean up process using scanning, re-drawing and printing in my work as an architect.
Thanks, Chris Wilkinson
Hi Chris.
I'm using Photoshop to pull in the drawings, stitch them together,
clean/sharpen them up, and then redrawing them line by line in some cases.
I'm terrible with autoCAD, as I never had a class or a mentor to show me
how to draft parts, and in most cases, I'm recreating am assembly, and
not a single part.
A friend has access to a 36" paper roll plotter. Otherwise, it is quite expensive.
beast44k
Post by beast44k »
I'm in the sign business and we use a program that works similar to cad.
You may price out large format digital prints on vinyl, it's overkill, but it will be more durable and it can be used later for a cool display.
384thBG
Post by 384thBG »
DryMartini wrote:Hi Chris.
not a single part.
Woof! thats a huge amount of work scanning, erasing and stitching. The file sizes must be astronomical. Boy, you need access to a large scanner. But if it works, don't fix it. I've used the same approach to save an old drawing, but added the step of importing the scanned sheet jpg into AutoCAD to trace it. If your project needs AutoCAD software or any assistance with the software send me a note.
If you are offering to draw a few parts in AutoCAD,
I have the parts for you to draw.
Just showing that work continues. One finds some really interesting stuff when going through
information like this. I should write a book sometime.
B-17C Skin installation info
