2015 RV-8 N9324Z
Quick Build (QB) or Standard Build (SB): Standard Build
S/N: 82932
Asking Price: $120,000
IFR/VFR: IFR
Why selling: Personal circumstances force this sale
Total Time (hrs) on airframe: 238 TT
First flight date: 8/29/2015
Original Builder?: Yes
Empty Weight (lbs): 1136
- CG (empty weight - inches from datum): 78.70 aft of datum to 86.82 aft of datum
- date of last weighing: 2015
Engine Make/Model: Lycoming YIO-360-M1B
- HP: 180
- Total Time Since New (hrs): 238; 195 tach time
- Ignition: Slick Mags
- Carb/FI: Fuel Injection
- Exhaust system: Vetterman
- Engine Purchased from: Lycoming through Vans
- Date of last compression check: 4/27/2019
- - Cylinder #1: 74
- - Cylinder #2: 75
- - Cylinder #3: 73
- - Cylinder #4: 77
Other features FWF: Oil Cooler shutter; oil analysis history available.
Prop:
- Make (FP or C/S): Hartzell Constant Speed (New with engine)
- Model: HC-C2YR-1BFP
Flaps (manual / electric): Electric
Rudder Trim (manual / electric): electric
Elevator Trim (manual / electric): electric
Aileron Trim (manual / electric): electric
Strobes Make/Model: AeroLed
Landing Lights Make/Model: Duckworks
Age of tires/tubes: New in May 2017
Avionics: COMM #1, NAV #1 & GPS NAVIGATOR: GARMIN GTN-650; Dynon Skyview SV-D1000T; Mode-S Transponder SV-XPNDR-261; ARINC Interface SV-ARINC-429; Autopilot Control SV-KNOB-PANEL/H; TFC/WX RECEIVER SV-ADSB-472; BACKUP BATTERY SV-BAT-320; SV-ADAHS-200; ENGINE MONITORING SV-EMS-220; AUTOPILOT SERVOS SV32 X 2; AUDIO PANEL PS ENGINEERING PMA5000EX; COMM #2: GARMIN SL-40; ELT ACK-406;
N9324Z is ADS-B 2020 Compliant.
Interior: Classic Aero seats and trim; Crow 5 point harnesses; Stein air vents
Modifications: Minor during build
Real World Cruise Figures:
- 175 kts TAS at 24" of MAP spinning 2400rpm while burning 10 gph.
Past incidents/repairs/damage repair: None
Service bulletins/Change notices that have been complied with: SB-14-02-05 elevator spar web; SB-16-03-28 aileron bracket; SB-18-05-21 Lycoming fuel spider; SB-14-01-31 Horizontal Stabilizer Cracks complied with during build with doubler added; SB-12-08-14 missing wing attach bolts complied with during build.
Date last condition inspection: 4/29/2019
- Maintained by: Owner builder Scott Thompson
Date last pitot-static-transponder check: 07/15/2019
Date aircraft last flown: October 2019
Willing to deliver: Negotiable
Detailed builders blog can be found at https://www.aerovintage.com/rv8/rv8-index.htm
Tail number N9324Z was last held by a B-17 air tanker...just FYI.
Contact Info
- name:
- email: [email][/email]
- phone: upon request
Photos
Re: Photos
Well Scott, any buyers ??? It's been awhile since I checked in here, did you have any offers on your little beauty ?
Re: Photos
Yes, the airplane sold quickly at close to the asking price...this was actually in October of 2019 so it's been a while. I miss not having that airplane in a hangar at the airport...but I don't miss some of the time and $$$ involved in keeping it there. The airplane has a good home with a good owner who loves to fly it.
