Posting Problems
Posting Problems
Sorry for folks having problems posting. I thought it was a few isolated cases but apparently it is more widespread. I'll try and figure out what is going on.
Re: Posting Problems
For what it is worth, the above post went right on to the board with no error messages. Not sure why some are having issues.
There seems to be some sort of timer that gives the "invalid" message if you take more than a few seconds to compose a post. Is it possible to reset that timer on your end, Scott?
See?
See?
Well, I checked the settings on the board and tweaked a few of them. Not sure it will do any good. No timeouts settings appeared to be enabled so posts should not have timed out. I will do some further research on the phpBB boards to see if I can track down the error.
