Latest Pictures for 41-2595
Just in time for Christmas!
Some repairs being made to the engine mounts prior to finishing:
The Tail gear treadle assembly, power coated, and looking good:
And finally, we got some welding action going. These are the base plates for the beam
assembly for the waist window guns:
Re: Latest Pictures for 41-2595
A few more -
Left Horizontal Stabilizer is coming together:
And the right stabilizer - missing only some rivnuts for the de-icer boots.
05564
Post by 05564 »
Glad to see things are taking shape. Maybe Santa and his elves could lend a hand after the Holidays to help speed things along. Thanks for sharing your update .
Lucky 13
Post by Lucky 13 »
Need a up date on the rat please
Keep the show on the road.
Well, it has been forever since I posted pictures. Not that I have not taken any.
Let's give a quick run-down on what has been happening out in Marengo in 2011:
First, we have been concentrating on the stabilizers since last summer.
We rebuilt the spars for the right horizontal stabilizer, and created forms for the
leading and trailing edge ribs. Last year, we pressed out a few, and replaced the
badly crunched and corroded ribs in the right horizontal. In it's skinless form, we took
it to Thunder Over Michigan, where many of you saw it. Late last year, it was skinned
and being riveted. Then we started on the left horizontal stabilizer. It was not in
any-where near as bad a condition of the right, and its rebuild went quickly. It is currently
back together, and almost completely skinned, awaiting some final riveting.
Here is a picture of the left horizontal stabilizer being re-skinned:
You may recall that we stretch formed the leading edge of the stabilizer tip. Well, here it is on the tip:
Next was the vertical stabilizer. The front rib, which is about 72" tall, is badly damaged, and
we are in the process of making/getting a replacement part. Again, the spar caps were
damaged, and required replacement. This was accomplished quickly, and after dis-assembly,
bead blasting, and priming, it went together fairly quickly. It is currently being skinned and
riveted. We have visions of the insignia yellow "12595" adorning the new skin.
The vertical stabilizer with ribs and hat sections being replaced:
Mike standing next to the vertical stabilizer (In May 2011):
We have also made progress in reassembling the cockpit and BLK #3.
More to come!
TAdan
Post by TAdan »
Thanks for the update. The stabilizers are coming along nicely.
So many warbirds so little time.
gary1954
Post by gary1954 »
Absolutely an Awesome job you guys are doing there.
As an now non-wrench bending JAFO/REMF I am very proud of you guys. Impressive, very impressive
Gary
" Never in the history of mankind have so many owed so much to so few." Sir Winston Churchill
You know, Gary, we can change that.
Come on out and get a refresher course
in riveting and wrench bending.
gary1954
Post by gary1954 »
LoL don't I wish, but ya never know, thanks for the invite
Gary
