There don't seem to be many shots of B-17s at Walnut Ridge around, but I caught images of four (two IDed by serial) in this newsreel excerpt:
https://www.youtube.com/watch?v=xhKYLuzyv5g
Is this Y code a late version of Dyersburg or is it from Williams, AZ? I tried enhancing the serial but it's very blurry; looks like 43-37XXX ending in 42 or 47; 43-37742 was a stateside trainer that last served at Dyersburg and ended up at Walnut Ridge - David, what do you think?
Left to right: Alexandria, Rapid City and Roswell. The one in the upper left corner might be another Alexandria plane - X K3? - but it's hard to make out.
EDIT: Found an image of Roswell W 091 - it's 44-8091:
Four more stateside trainers at Walnut Ridge
Re: Four more stateside trainers at Walnut Ridge
Edited to add new info.
Ordered the film- 4 bucks is about what is was worth. Still not the best, but some interest stuff when you step through it
Y-M2
X-K4
Triangle-W / letter V
Y-M2
X-K4
44-6347 - ex swiss internee
42-5310
100th BG aircraft - side codes deleted
42-5310
