Been deathly quiet around here, so:
https://www.ebay.com/itm/Org-Photo-B-17 ... rk:18:pf:0
Osborne lists it as only lasting two months from delivery to salvage after being strafed on Java.
Attn shoppers: B-17E 41-2488
Re: Attn shoppers: B-17E 41-2488
and a tail of another to the right...............varsity07840 wrote:Interestingly, there's a P-39 in the background on the left.
41-2488 (c/n: 2299).
Assigned: 7th BG / 30th BS
Ferried: January 1942 - (Florida - Africa - Singoasri Field) - (Pilot: 1Lt John D Bridges)
Project X
Assigned: 6 February 1942 - 5th AF / 7th BG / 9th BS - (Singoasri Field)
Destroyed: 20 February 1942 (Bombing / Strafed) - Singosari Field, Java (Aircraft was parked) - SOC.
Project X
So, the picture was taken stateside? There were no P-39s in Javaterveurn wrote:41-2488 (c/n: 2299).
Project X
- OldBillB17F
Thanks for sharing the photo. Here is a photo of 41-2488 following the strafing on Java.
That identification of the B-17E as 41-2488 has been questioned. It seems more likely it's 41-2486, which ended up with the 19th Bomb Group in Australia. It would be good to get a much closer look at that photo.
You may be on to something:
Bid is up to $40.99 so I'm out.
And sold for $108.49.
