Rebuild of B-17F 42-3455 "Lucky 13"
- OldBillB17F
Re: Rebuild of B-17F 42-3455 "Lucky 13"
Great stuff! Can you explain what an "outer compression strut" assembly is, and where does it go? Also, is the last piece you post part of the underside nose structure? Thanks.
Hey Ray,
It's Eric Miller with Project Warbird Salvage/Museum up in Asheville. I just found this forum with your project from someone posting it on WIX. AWESOME work!!!!!! Did the parts you bought from me work out? I have a few boxes of parts in my shop that I don't know what they go to. You can dig through them if you want. I also would love to come down and see Lucky 13.
Eric Miller
Project Warbird
Salvage/Museum
http://www.projectwarbird.com
1-888-504-5777
Eric Miller
Project Warbird
Salvage/Museum
1-888-504-5777
Tim,Great stuff! Can you explain what an "outer compression strut" assembly is, and where does it go? Also, is the last piece you post part of the underside nose structure? Thanks.
That's the truss structure on the sides of the bomb bay.
The bottom strut is where the bomb bay doors attach.
Oh, and I have DVDs for you.
Contact me via email.
- OldBillB17F
Thanks Bill. Email sent.
Ray,
It never ceases to amaze me what all you have accomplished and where all these parts are going to.
Keep HANG THE EXPENSE busy and try and keep him from cussin' too much.
Uncle Marvin sure would be proud!
Don
Don
SPANNER
Mr. President and the U.S. Congress... We are forever in your debt!
- hang the expense
Spanner, Your tagline is one of the reasons I cuss so much.Its dang perfect.
I have finished drilling the pilot holes in the bottom outer compression strut tubes,they are for the bomb bay door hinges.All 567 of them.
I will be working on the bomb bay door hinge brackets next.
Also picked up a set of rudder peddles for lucky
Keep the show on the road.
Well done, keep pecking away! Always amazes me the volume of work you do.
- OldBillB17F
Mad skills.
I have all of the bomb bay door hinge brackets cut for all six planes
I have all so started milling them to the right size
- hang the expense
Come on Ray, don't make a career on those brackets.
Latest Update: B-17F 42-3455 "Lucky 13"
Ray has texted me a bunch of photos, and asked me to post them here.
Enjoy!
Bomb Bay Door brackets by the dozens....
Gusset plates for the compression trusses, and the catwalks
Sorting through all that material
Compression struts in the making
Another angle
More to come!
Enjoy!
Another angle
More to come!
Ray's New Shop
Here are some images from Ray's shop move.
If it is anything like his last place, you can eat off
both the floors AND the walls.
Machinery - Milling the end off a longeron
Compression struts in the jig
Moving some of his prized wreckage
Nose keel in the jig
Another view of the nose keel
